Copy select fields on 'Copy Sent Data to New Survey'
1156
06-06-2023 06:49 AM
SamuelSchneider
Hi there, I am looking to limit what fields can be copied when copying sent data to new survey.
Is there a way to limit what fields are copied when the 'Copy Sent Data to New Survey' action is performed?
I have a few repeat tables on a survey that I do not want to be copied.
Thanks, Sam
ZacharySutherby
Hello @SamuelSchneider
It is not possible to specify what questions are brought over when copying to a new survey. When a survey is copied to a new survey an identical replica of the old record is created (with the exception of attachments/files). The best way to set per question values is to save a record as favorite and each time the favorite is pasted those values will be present.
Thank you,
Zach
ThaissaCaino
hello!
We have an update about this query?
