We've encountered an issue in 2 of our surveys, where no errors were found in Survey123 Connect, and after recent [Publish], surveys won't send from the Field App.
The error message says the following:
Send Error
This survey could not be sent due to the following error:
Cannot create a row of size 10196 which is greater than the allowable maximum row size of 8060. The statement has been terminated.
This has not been an issue before, with only minor changes being pushed in the last [Publish]. We've checked the limits of all fields, and the package which is sent, and both are nowhere near the 8060 limit. The stated number (10196) gets bigger after every [Publish], as if it's accumulative, rather than replacing the previous error.
We're aware this is a SQL error, and wonder if any changes have taken place from the ESRI side which could have resulted in these errors occurring.
For reference, our surveys are very big - up to 750 rows on the Excel sheet, but haven't encountered this issue until the past 2 weeks, where 2 of our surveys have fallen over. Each time, we've been able to create a new Project, copy/paste the files, and it seems to work perfectly.
We're almost at the stage of going live with this project, and fear the loss of data if these surveys fall over if we publish an update once LIVE.
In the end, I had to copy/paste my survey as a new project. There was no explanation for the issue, other than 'something had corrupted'. New project works without issue.
hi,
We recently, had experienced the same issue. It happen when we conducted our survey on field apps.
We previous, do the same survey online via web application with no such issue showing up.
We're also waiting for further response from ESRI
I had this issue also i was able to resolve by setting the majority of my calculation fields to null types ( I had a large number of pulldata(@layer) calcs in my form ). if you have the option of doing this also consider using integers where possible to reduce the size of the row count.
Hi @PaulSweeney3
Thanks for your comment. We do have a lot of fields, pulldata calls, and calculations on our forms, but these are all required for functionality.
The strange thing for us, is that saving the survey as a new project (all rows intact) somehow works flawlessly. This suggests the SQL database is corrupting somehow, rather than it being any limitation on the form itself.
Greetings.
Have you managed to find a solution to this problem?
Posting for anyone else who might see this later or if you happen to run into this again, I would second what @PaulSweeney3 mentions above. My team and I have a large survey (~700 fields) that has been live for several years and just ran into this publish issue when making updates. We would have been adding 278 fields (with calculations & relevant logic) but ran into the row size issue when trying to publish in our QA survey.
We were able to avoid adding that many fields to the dataset by using 'null' in the bind:esri:fieldtype column - published fine. We would NOT have been able to republish a brand-new survey (copy/paste) without losing our existing data set and connections (that house over 80k records to date).
Check out this blog for more information: The Power of Nothing - Esri Community
@MollyBurton glad my experience was able to help you
