Connecting a Survey123 submission to a polygon, not a georeferenced point
407
10-31-2024 12:23 PM
RH2024
I am using Survey 123, ARC GIS Online, and Map Viewer.
I have a polygon layer showing different fields.  In the polygon pop-up I have a Survey 123 link that pulls field name and other information into the survey.  I complete the survey in the field and in Map Viewer, I now have georeferenced points that I can click on and see my survey information.  After my second round of data collection, I now have double the number of georeferenced points that clutter and confuse the map.
Is there a way that I con consolidate the data points into the polygon layer.  I want to be able to click the polygon and the pop up contain "links" to each survey entry as well as the link to the survey itself.
Rather than a number of georeferenced points, can I have the polygon that contains each survey taken?
