configure specific scale in a report for a geopoint
623
11-12-2019 11:55 AM
DiegoLlamas
I would like to know if is possible to configure the image of the map when I export a report in survey123.arcgis.com for a larger scale.
this is my default scale in the report
And i would like that by default this scale be shown
is it possible? how can this be reach?
Regards,
Diego Llamas
JamesTedrick
Esri Esteemed Contributor
Hi Diego,
The feature report service defaults to the form's default scale, which can be controlled through Survey123 Connect or the web designer.  You can override the default map scale in a report through the mapSettings properties in the report.  Refer to Feature report templates—Survey123 for ArcGIS | Documentation .
