Combining Surveys using submission_url problems
756
06-06-2018 04:04 PM
AdamDaily
I have several custom surveys made for different field groups collecting different data. I want to combine all of their results into 1 feature service. I published a new survey containing all attribute fields from all of the surveys. This created my new feature service. I then made copies of my existing surveys and added the submission url and form id to them to write to the new feature service and published those. That all worked as expected.
Now, when I collect a feature, everything stops working. I compared by collecting the same feature using my original survey, and again using the new copy pointing to the new feature service. Results are seen below. The result was everything I had built into my survey breaks down and stops working. Default field values don't populate. Calculations stop calculating. Pulldata functions don't pull over any data, relevant statements stop working and break down the work flow, etc. Why?
Original
New
JamesTedrick
Esri Esteemed Contributor
Hi Adam,
Can you provide the form materials to test with?
