Collector to Survey123: handing over attribute values
799
01-13-2017 06:01 AM
Nicole_Ueberschär
Hey folks,
I managed to hand over the OBJECTID when opening my survey from Collector. When testing on Windows Desktop I could also hand over the code for the landuse when opening the survey from the web map.
To give you an example: In Collector I have a polygon layer to collect plots. Through a domain I have coded values corresponding to my survey. In the feature class it's the attribute Landuse_id that should be handed over to the question called landuse. For example the code 99 represents Non crop land. In Survey123 for Windows Desktop the corresponding select_one field is selected when opening the survey from the web map but unfortunately not when I'm opening it out of Collector (tested with iPhone and Android tablet).
This is the link I'm opening in Collector: arcgis-survey123://?itemID=eae498ec6b164d37aaf1a2805e2b0fc3&field:id={OBJECTID}&field:landuse={Landuse_id}
Any idea how to solve this?
