Code 0 Error and inbox is being wiped when launching surveys from Field Maps hyperlink offline
2257
05-25-2023 05:30 AM
JohnHuillery1
I have a Field Maps app that has a hyperlink to launch a survey123 inbox record from a pop up.  When I attempt to open the survey from the hyperlink in Field Maps when I'm offline, I get an Error Code 0 and the contents of the inbox disappears. This did not happen before I upgraded to Connect 3.17.54. It works fine when I'm connected to the internet, but my users will always be offline.
2 Solutions
ZacharySutherby
Hello @JohnHuillery1
If you have update=true in your URL linking Field Maps to Survey123 this is logged as BUG-000157932. What's happening is with update=true, Survey123 is trying to reach out to the feature service to refresh the Inbox, but since the device is offline the request fails causing this issue.
As a workaround I would suggest in your pop up having two URL's one when for use when online that includes the update=true URL parameter and one for offline use that omits the update=true URL parameter.
Thank you,
Zach
BrettStokes
Hi @JohnHuillery1, we believe we will address the cause of this issue (BUG-000157932) in our upcoming 3.18 August update. The builds are available for testing now via the Early Adopter website if you'd like to try it out?
Brett
ZacharySutherby
Thank you,
Zach
BrettStokes
Brett
