Choice Selection is Displaying Label Result, not Name Result in Backend
594
02-07-2020 08:51 AM
RobertMarros
I am noticing that for a survey I created, the results in the backend for my choice selection is displaying the Label result and not the Name result. Here is an example:
The image below is a copy of my spreadsheet's "Choice Tab," where you can see two choices for "status," pass and fail.
In the name field, I have pass and fail as my two options, with the label coloring them so Pass is green and Fail is red in my survey. However, in the backend, the results for my choice selection show up like this:
Why isn't it using the results from the name field like it does for every other question in my survey?
Is there some kind of default? Why would it use the label result in some cases and the name result in others?
James TedrickSurvey123 GeonetSurvey123 Geonet#survey123 autoselection‌ #survey123selection
RobertMarros
Figured out how we can change the results in the backend from a choice selection result label by altering the feature service through the Data>Fields option:
 Then
Then
Note that this only works for Select One Choices, not Select Multiples.
Thanks!
