Choice filters using a hidden calculation field?
831
12-22-2020 02:48 AM
Anneka_France
Occasional Contributor III
Is it possible to set up a choice filter using a hidden calculation field, rather than a select_one or select_many field?
For example, we have a hidden field (${organisation}) with the calculation:
if(${total_score}>=10, 'organisation1','organisation2')
I then want to apply a filter to a choice list based on the value of this field. I've followed the steps above, but it doesn't seem to work. Am I missing a step? Or is it because it's not the correct field type?
Anneka France
Technical Manager at The Rivers Trust
Hussam_AlJabri
Hi, could you please share your XLSForm so I can support on this regards.
Jing_Sun
Hi Anneka, I created a sample using default field type, please see the screenshots below.
Cheers
IsmaelChivite
Esri Notable Contributor
Hi. Yes, this is possible.
For example, here I calculate the Body Mass Index of a person and use that value to present menu items in a list. The Body Mass Index is hidden to the user.
The same goes with your original example, which should work well.
I am guessing that your version of Survey123 Connect is old. If you are running using the latest version, attach your XLSForm to a reply.  There might be something else we could not see in your screenshot.
