Check to see if I can use an existing Choice list
792
02-18-2022 06:29 AM
JohnHu
I have an existing Choice listing called "FFTP".   This contains pipelines and facilities for Florida and also contain some for Alabama.  Now I need to add a choice on the Survey123 form for Alabama,  and only lists those facilities contain "Lowman" from "FFTP" list belong to Alabama.   Due to linking with other external system such as Maximo,  I like to minimize possible changes with related external system and try to see if I can accomplish with all tricks in Survey123.   So far,  I have not been successful.  If I add "FFTP       Alabama",  the Alabama choice does not show up.  If I add "FAL      Alabama",  the Alabama choices show up.  This would mean that I have to add "FAL" to our external Maximo system.  I like to check and get help on if I can accomplish my desired change,  i.e. use existing FFTP choice list and not add "FAL" to show Alabama choice on the form.  Your help will be greatly appreciated.
Tags (1)
JohnHu
Try to achieve the attached form changes without adding a new name called FAL and only using existing name called FFTP.  The reason is to avoid more complex changes in other related system such as Maximo.  Please help.   Thanks.
