Character limit for survey names?
1130
05-03-2022 06:18 PM
Katie_Clark
MVP Alum
Is there a character limit for survey names? I am unable to publish a survey and this is the error message I get, but there's no way to view the full message so that's the only thing I could think it might be:
P.S. The fact that I can't expand to view the whole error message is definitely an oversight for the interface. Would be great if Esri could correct that soon! 🙂
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
DougBrowning
Yes table names are field names are limited to 32.  One that can also get you is repeat count.  It will add a field with repeatname_count so that all has to be under the 32.  I have even seen once somehow I table name got
I had the help doc on this and now cannot find it.  But I think SQL Lite and AGOL have the limit.
Some mention here  https://doc.arcgis.com/en/survey123/reference/survey123withenterprise.htm#:~:text=The%20name%20of%20....
DougBrowning
Katie_Clark
MVP Alum
Ok, thanks for clarifying Doug!
Best,
Katie
