Character limit for survey names?
1530
05-03-2022 06:18 PM
Katie_Clark
MVP Regular Contributor
Is there a character limit for survey names? I am unable to publish a survey and this is the error message I get, but there's no way to view the full message so that's the only thing I could think it might be:
P.S. The fact that I can't expand to view the whole error message is definitely an oversight for the interface. Would be great if Esri could correct that soon! 🙂
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
DougBrowning
MVP Esteemed Contributor
Yes table names are field names are limited to 32.  One that can also get you is repeat count.  It will add a field with repeatname_count so that all has to be under the 32.  I have even seen once somehow I table name got
I had the help doc on this and now cannot find it.  But I think SQL Lite and AGOL have the limit.
Some mention here  https://doc.arcgis.com/en/survey123/reference/survey123withenterprise.htm#:~:text=The%20name%20of%20....
DougBrowning
Katie_Clark
Ok, thanks for clarifying Doug!
Best,
Katie
