changing names of survey are not being updated on "downloads" for mobile device
1160
12-07-2017 12:29 PM
Lake_Worth_BeachAdmin
in survey 123 connect I am changing names of older surveys (but do not want to delete at this time) to identify out of production. however on mobile devices when a user wants to download a survey they are not seeing the updated names. the original names of the survey appears, my end users get confused for which survey to download. (they could check last edited date) but heck thats asking a lot of some people
CarmelConnolly
Hi Joe,
When you changed the name in Settings > General, did you republish the survey?
Another way to do it is to edit the name of the Form item in Content.
Carmel
JamesTedrick
Esri Esteemed Contributor
Hi Joe,
Instead of changing the names, I would recommend uncaring the surveys so that others cannot submit information to them.  How are you changing the name of the Survey- are you only doing so via the ArcGIS Online Item Details page?
I was changing the names in survey123 connect in the general settings tab.  The name gets updated in connect but not on the mobile devices when trying to download surveys.
CarmelConnolly
Hi Joe,
Carmel
thank you, apparently I did not re-publish.....
