Changing Font Style in Survey123 App (Korean)
1559
7
09-26-2017 04:08 AM
CalvinKwon1
New Contributor III
Is there a way to change the font style in the mobile app?
The Korean font looks 'cutesy' and it does not look very professional!
Any help would be greatly appreciated
JamesTedrick
Esri Esteemed Contributor
Hi Calvin,
아이구!  Thanks for bringing this up- would you have a suggestion of a more appropriate font by name?
JamesTedrick
Hi Calvin,
I'm attempting to replicate this, but I'm not seeing the same font, see below (the first phrase below was what came up when I searched for a sentence that uses every letter).  I'm wondering if this might be a system font issue on your phone - can you test on other devices?  Can you let me know what device you are using?
CalvinKwon1
New Contributor III
James, thank you for checking.
I am currently using Samsung Galaxy Note 5, but I have checked it on Samsung Galaxy TabS as well as other smartphones. I've never changed my system font...could you let me know how I could troubleshoot/check?
Thank you!
JamesTedrick
Hi Calvin,
Can you take a look at
Settings > Display > Fonts
and see if there is a list of fonts available?
Also, can you share the XLS file of your survey so I can check to see if it might be something to do with text placement in the survey?
CalvinKwon1
New Contributor III
Hi James,
There is a list of fonts and mine is set to "Default."
The screenshot of the survey is the default survey that was available when I downloaded Survey123 mobile app. Do you have access to it or shall I send it to you?
JamesTedrick
Yes, please forward the form.
Also, can you try changing the fonts and see if there is a better one?  'Noto' fonts should be non-brush-like
CalvinKwon1
New Contributor III
James, here is the link to the file.
파주시 산란계 및 육계 농가조사.zip - Box
