I am making a survey that will be filled out for a 20m x 20m grid system. There are over 100 individual squares that need to be surveyed. I have a web map with a polygon layer of the grid. I want to have an attribute field called "Completed" change from 'No' to 'Yes' when a user submits a survey entry that matches the grid number for a specific square.
Does anyone know if it is possible to change / update values in an existing feature layer based on a response from within Survey123?
I haven't been able to find much info on this (using S123 Connect)
