Change the post-submit screen text in Survey123?
28456
55
02-20-2018 11:33 AM
deleted-user-z2GLgII8IrQ9
After you submit a survey the following screen says "Great! Your data was sent successfully. Thanks."  and has a link labelled "Please click here to submit again.".
Is it possible to change these messages?
Mike
Tags (1)
EricKriener
is there a place to change this part? -- "Press here to submit another survey."
I'd like it to not say 'survey'
AJ_devaccount
Hi @Anonymous User just checking in about the custom thank you screen: is it still not possible to pass input values from the form into a custom thank you screen after submission? Specifically, I wanted to add a hidden field (calculated using the user's inputs, thus passing URL parameters) as custom hyperlink.
Thanks very much,
AJ
FranciscoAndrade1
John,
When the survey was created, we used Connect.
StephanieHickel
Hey John,
I created my survey in Connect and am trying to customize the submitted survey message. I have opened up survey 1,2,3 in a web browser and when I hit the "Design" tab I don't have any of this functionality. I receive a message stating, "Open URL: arcgis-survey123connect? Therefore it seems the only way to change the design is through Connect. Am I missing something?
Best,
Stephanie
JohnathanHasthorpe
Hi Stephanie
Once you create or edit a survey in Connect, you can't modify it using the web designer. This is the issue you are seeing. If possible (i.e. depending on the functionality you require) you would need to create the survey in the Web Designer.
John
JohnathanHasthorpe
We are looking to get this feature added to 3.3 - This would allow users to modify the thank you screen for web surveys originally created in Connect.
AllenRisley
THANK YOU!!!!! What’s the ETA on 3.3?
Allen Risley
GIS Specialist
Academic Technology Support
Instructional & Information Technology Services
California State University San Marcos
Office: Kellogg 2437
Phone: 760-750-4169
Email: arisley@csusm.edu<mailto:arisley@csusm.edu>
#ThoughtsBecomeThings
JamesTedrick
Esri Esteemed Contributor
Hi Allen,
We anticipate 3.3 to be released at the ned of the month.
OussamaMerhi
yes exactly but it seems that you cant manage it yet through survey123 connect.
MarkLache1
Yes I'm looking to change my submit screen through connect as well
