Change 'Submit' Text in Survey123 Connect
10819
14
12-15-2020 12:17 PM
RenéGonzalez
Is there a way to change the 'Submit' text in the submit button in Survey123 Connect? My organization wants to change the text to 'Locate'. I know this is possible in the Survey123 Web Environment, but due to using the PullData function, I had to create this survey in Connect. I checked the form.webform file in the folder structure to set this parameter but seemed to not work.
Anyone know where I can change the text in Connect?
Any help will be greatly appreciated!
YasserMroue
Hello I'm struggling with this issue. the submit text  isn't appearing. any help
JayJohnsonWashoeCounty
Are you using "ArcGIS Survey123 Connect" v 3.11?
Jay
Washoe County GIS
YasserMroue
hello as the app start it show 3.12
ZhifangWang
Hi @RenéGonzalez ,
If the survey is published from Survey123 Connect, you can use a note question named generated_note_form_submit_text  in the XLSForm file to change the submit button in the web app, please see the details in this help topic. Note: this starts to work in 3.11 version, if your survey is older than it you need to republish the survey by using a new version of Survey123 Connect (>=3.11).
@YasserMroue ,
If your survey is published from the web designer, please check if the submit button text is deleted accidentally or set a wrong color in the Appearance->Theme section.
If the survey is published from Survey123 Connect, please refer to the note above and check if it is overwritten in the XLSForm file.
Zhifang
YasserMroue
hello Zhifang, thanks a loot that was the problem, it was written but there was a problem in the color code.
