Is it possible to change the layout of the concepts and outbox page in survey123?
Our colleagues sometimes need to wait for more data before submitting a survey. While waiting for the data the survey is added to the concepts or outbox folder. The default page doesn't show much information about the different surveys (see example attached). Can the layout be changed by showing different fields and showing the first picture taken?
Hi Niels
I think what you are trying to do is change the instance name of the records. You can do it by manipulating the instance name setting of the survey. Here is an article about it https://community.esri.com/groups/survey123/blog/2017/04/24/understanding-the-instancename-setting
Thanks!
Is it also possible to show the first picture taken?
No unfortunately not... unless you customize Survey123 with AppStudio
