Change geopoint marker
2376
10-18-2023 12:37 PM
mikaël
Yet again trying to decipher esri's cryptic and convoluted documentation!
Can anybody help me trying to change the default marker when creating a geopoint question in Survey123 Connect?
From what I gather hereit seems to be possible to change the icon with one of these without having to download it and put it in the media folder, but I cannot seem to manage this task, probably reserved for our best and brightest.
Thanks for your help!! 🙂
IsmaelChivite
Esri Notable Contributor
  • Create a PNG file (dont make it bigger than 512 by 512 to keep the size low
For example: I downloaded gardener.png from FlatIcon
  • Copy it into the media folder of your survey
  • In the body::esri:style, for your geopoint question, reference the PNG file as shown below
  • Download and test in the mobile app
Gotchas:
  • You were looking at the wrong help topic section. The correct help topic section is called Geopoint symbology here: https://doc.arcgis.com/en/survey123/desktop/create-surveys/geopoints.htm#ESRI_SECTION1_DF5D4AC0546B4...   Geopoint symbology and overlays are different things.
  • The above will work in the mobile app. Will not work in the web app
  • Make sure the name of the file you reference in the XLSForm matches exactly the name of the file you copied to the media folder
  • The PNG file is placed horizontally centered at the location but vertically, it uses the bottom of the PNG. If you want to center your PNG exactly at the location, use the x y parameters as follows:
symbol=gardener.png?x=0.5&y=0.5
IsmaelChivite
Gotchas:
mikaël
I wished it was possible to do without setting a custom image in the media folder, but I guess that's not  an option right now.
Thanks for a great answer!
ahargreaves_FW
@IsmaelChivite what if I already have something in body::esri:style such as 'map=xyzxyzxyz' ?
SLowman_NCE
Does this change the marker in a report that's generated from the survey?
