Cannot Upload .HEIC photos to Survey123 field app
1943
8
11-27-2017 09:56 PM
by Anonymous User
Not applicable
After updating my iPhone to iOS 11, I have noticed that my photos are in .HEIC file format rather than the usual .jpg format.
But, these files cannot be uploaded via the Survey123 field app.
To get around this, I have reverted my camera settings to take .jpg rather than .heic
But, it would be great if this could be fixed ASAP. As, most of my clients are on ios11
THANKS
James TedrickMichael Kelly
JohnathanHasthorpe
Hi Geethaka
This is a known limitation of the QT framework Survey123 is built with. Once QT add support for the image format, we will add it into Survey123.
FYI here is the QT bug number: [QTBUG-63638] [iOS] Add support for HEIC image format - Qt Bug Tracker
You have implemented the recommended workaround.
John
brward
Has this bug been fixed yet?
RobertAnderson3
MVP Regular Contributor
I believe it has yes, when an HEIC image is attached to Survey123 it converts it to a JPG but it let's me attach them.
brward
Ive noticed specifically on mobile or tablets that it does convert automatically to a jpeg. But when someone attaches an HEIC to a survey through a mac it does not auto convert. Know of any workarounds for this?
RobertAnderson3
Ah that's an interesting quirk, I'm not sure, I have never implemented any surveys on Mac so I haven't experienced this. Though it makes me wonder if that also applies on Windows..
brward
I tried it just now and it has the same issue of not converting an HEIC to a jpeg on windows as well. It does give the error code of 'The following file types are not supported: .heic'. I made this survey through connect on 3.19 version FYI.
RobertAnderson3
Interesting. Is this purely the web form or the desktop version of the field app as well? It might be worth contacting support to let them know, or posting an idea in the forums to make the web form convert them as well.
I see a similar issue recently posted here: Survey123 and HEIC images - Esri Community
brward
It doesnt seem to like it in the desktop version of the field app either. When I use a mobile device in the web form and in field app it doesnt have this issue with HEIC conversion. Its a specific issue that i will definitely bring up to support. Thank you for your time Robert!
