Cannot read property 'username' of undefined
1697
05-18-2020 08:23 AM
AndrewMilanes
Occasional Contributor II
Using Portal 10.7.1, I'm trying to create a sample report template using the S123 website connected to my portal.  I get the following error when I select create sample template:
"An error occurred while saving the report template.  Cannot read property 'username' of undefined."
An older version of this survey contained a field for username, but I've since deleted it.  I deleted the form and feature service and republished, but I'm still getting this error.  I looked through all of the json and xml files and don't see reference to this field.  What am I missing?
ZacharySutherby
Hello Andrew,
Is your ArcGIS Enterprise Portal configured with Integrated Windows Authentication? Additionally, is your Portal publicly available? Meaning if you were to try to hit your Portal from home without a VPN or from Starbucks, for example, can you successfully hit your Portal outside of your network?
If either of those is true the error is expected, please use the ArcGIS Enterprise Support section of this article for reference:
https://community.esri.com/groups/survey123/blog/2019/07/23/understanding-survey123-feature-reports
Thank you,
Zach
Thank you,
Zach
AndrewMilanes
The Portal is not configured with integrated windows authentication.  The Portal is not publicly available.  A VPN is required for access.
So since my Portal is not public, Feature Reports are not available?
ZacharySutherby
Hello Andrew,
That is correct because the Survey123 ArcGIS Online Feature report service needs to be able to reach your ArcGIS Enterprise Portal to process.
Thank you,
Zach
Thank you,
Zach
MicheleJett2
Hi Zach,
Does the Survey 123 ArcGIS Online Feature report service always have the same IP address?
Michele
