Can you use 'or_other' with 'select_one_external'?
958
12-27-2017 12:36 PM
TL2
My select_one as well as my select_one_external via choice filter work fine.
When I add or_other to the select_one_external it does not.
Just want to make sure this is by design and not my error.
Thanks.
JohnathanHasthorpe
Hi Tucker
This is an existing limitation of Survey123. We have a bug open to get this resolved.
John
DataOfficer
Johnathan Hasthorpe‌ have there been any developments on this or any idea when it will be fixed?
JamesTedrick
Esri Esteemed Contributor
Hi Rob,
Unfortunately, while the XLSForm specification doesn't mention one or another whether this should be allowed, the XLSForm validation tools Survey123 uses does not allow for 'or_other' to be used with an external select.  Given that this can be addressed by adding an 'other' choice to your list and a dedicated 'other' question (which is a more robust solution for translation and to consolidate answers to one field via an if() statement), there have been no developments to address this.
