Can you edit a repeat of an already submitted record?
6364
17
07-24-2018 02:28 PM
ElbaMolina
Can you edit a repeat of an already submitted record??
I'm using Survey123 Version 3.0.132 for IOS 11.3.1
Apparently not, because when I try to edit the sent survey data with the option "Edit and resend survey", the first group of answers dissapear, only shows the second group (iterated 2 times)
JohnathanHasthorpe
Hi Mathew
Could you please share your survey with me?
John
deleted-user-AHEapLrN7M1u
Hi John,
See attached.
Matt
JohnathanHasthorpe
Can you also confirm the app version number you were testing? The survey looks to be working for me.
Hi John,
The app version that I am using is 3.0.149 and the AppFramework version is 3.1.113
The survey itself has been edited using Connect version 3.1.126
The app is currently being used by a high number of field employees, I do not know what version each of them is using.
JohnathanHasthorpe
Hi Mathew
We have just released version 3.2 of the app - please update to this version to resolve your issue.
John
Hi John,
Updating the Survey123 app solved the problem. Thanks for all of the help!
Matt
OrçunAkkay
Hello, I have an issue. I am using repeats in my excel form of survey. I have added "allowUpdate=true" field to the form. I can make updates from the mobile application but i can not do that in web. Is there a way to edit existing data in webpage?
by Anonymous User
Not applicable
Hi Orcun,
Yes, you can also edit a survey via the web app using web app URL parameters. See the documentation here Integrate with other apps—ArcGIS Survey123 | Documentation and this great blog post for more information: https://community.esri.com/groups/survey123/blog/2019/02/06/survey123-tricks-of-the-trade-web-form-u....
You can also edit a survey via the Data tab of the Survey123 website. If you select a record in the data table, you will see a preview of the survey record on the right hand side, and an edit pencil button that allows editing the survey record.
Regards,
Phil.
