Can the map view in Survey123 be made the default view
878
03-06-2020 05:25 AM
BenWalker
When using Survey 123 can I change the default behavior of the inbox so that the map view displays rather then the list view, when first opened?
by Anonymous User
Not applicable
Hi Ben,
Unfortunately this is not possible, there is no option or setting to change the default view when opening the Inbox.
I encourage you to submit an enhancement request via Esri Support. Our Support team will assign an official enhancement number for your records. Similar requests from other customers can then be attached to the same enhancement request, which helps us assess demand for the enhancement and prioritize it accordingly.
Regards,
Phil.
