Can't figure out how to write the proper regex expression in the relevance column
371
5
07-08-2025 12:19 PM
Jonatanson_DUC
Hey all!
I'm having trouble figuring out how to make a repeat appear or not based on the answer of two questions: a yes/no and a select_one question.
Scenario:
User choose No in Question 1.
User chooses a single value in Question 2 - which is a select_one: N/A,1, 2, 3, 4... up to 100.
These values are saved in the Choices spreadsheet.
If a users chooses N/A or 100, I need a repeat to NOT appear.
If they choose values between 1-99, the other repeat will appear.
Right now I'm using regex expressions in the Relevance column as such:
regex(${Question_1}, "n") and regex(${Question_2}, "[1-99]")
I've also tried listing all the values as below (except they keep going):
regex(${Question_1}, "n") and regex(${Question_2}, "[1,2,3,4,5...]")
Both of the above work except if I select "100", then the repeat shows up.
Any ideas are appreciated!!
Tags (3)
Neal_t_k
What about something like this:
selected(${Question_1},"No")  and (not(selected(${Question_2} ,"NA")) and not(selected(${Question_2} , "100")))
and on the other repeat:
selected(${Question_1},"No")  and (selected(${Question_2} , "NA") or selected(${Question_2} , "100"))
Jonatanson_DUC
Hey @Neal_t_k !  Thanks for the reply.  Maybe I wasn't clear in what I'm trying to do.
Here's a better breakdown.
Question_1 options: Yes/No
Question_2 options: N/A, 1, 2, 3, 4... 100
If Question_1 = Yes then Question_3 remains hidden on the survey
If Question_1 = No and Question_2 = N/A or 100 then Question_3 remains hidden on the survey
If Question_1 = No and Question_2 =any of 1, 2, 3, 4...99 then Question_3 appears on the survey
Hopefully that makes more sense.
Neal_t_k
This should be what you want for question 3 in that case.
selected(${question_1},"no")  and (not(selected(${question_2} , "N/A")) and  not(selected(${question_2} , "100")))
Jonatanson_DUC
That's not it either.  When I enter that expression, Question_3 doesn't appear under any circumstance.  It's hidden for all Question_2 selections.
Neal_t_k
@Jonatanson_DUC here is a working example.
