Can Survey123 results populate a feature class in an enterprise geodatabase?
817
11-02-2023 09:34 AM
Alec
I am making a survey for internal use. I am planning on creating the survey in my organizations portal. Is it possible for the results of the survey to populate a feature class in my organization's enterprise geodatabase? I have created noting yet, just trying to understand possibilities and limitations of Survey123
ezirhli
Hi @Alec  yes you can do this.
Your workflow should be like this: You should publish a service from the database and create the Survey123 application using that service.
I am adding the relevant ESRI source.
Working existing data
ezirhli
Alec
Thank you! I was able to accomplish what I needed following that workflow.
