Can not submit survey
628
05-28-2020 12:43 PM
NusratFatema1
Hi ,
I am having trouble sending a survey using S123. I am using a non- hosted feature service. feature service has create, update, delete  and sync enabled, has a global id, archiving on and unregister as version.  I have attached two images of two different error messages that we got.
 Would applicate your response
Best
Nusrat
JamesTedrick
Esri Esteemed Contributor
Hi Nusrat,
Apologies for the delay.  It would be helpful to get a troubleshooting log to see if there is a more detailed message.  See Troubleshoot—Survey123 for ArcGIS | Documentation  (note that you can log to a file without needing to connect to a console).  You could also open a support case with Esri support to get help in troubleshooting this.
