Hey everyone.
I have set up a Survey 123 in order to serve as the primary interface for grass cutting contractors here in the city.
The kicker is, that I need the data to be edited from and back into a related table to the feature service (1 to Many). The relationship is also not set up with a Global ID, as I can not afford to have the GUID setup as a primary key on my Enterprise SDE.
The Set up: Service requests are created in a Feature Service and a related Task is created for Cutting the Grass. The Survey is to pull the data from the related table only (not using repeats), get updated/ edited, and then submit the updates back into the related table.
I have set the Survey to point directly at the related table. I have set up the bind:esri:parameters as suggested in this post: Repeat questions in 'Inbox' not showing from the very bottom.
The Survey publishes fine, but when I attempt to bring in the Inbox it just spins forever. It should only be returning 5 sample datasets, so this should be pretty quick right?
I've attached the set up to this post.
