Can I use a calculated value name on default column of a select_one type?
1385
06-23-2017 07:09 PM
RenatoSalvaleon
On a select_one missionList with choices 10,20,30,40,50. I'd like to make my default value on this attribute as a calculated value named ${DefaultMission} so the right name is selected in the list. So if my Company is APC the default missionStatus is 20, if Company is SCS, the default is 10, etc. When I tried this the calculated value became null.
RenatoSalvaleon
I ended with using a cascading select for this question. I'm looking forward fort he search function to be supported for a more dynamic list.
RenatoSalvaleon
