Can I create a webhook for a survey I did not create?
1197
11-27-2019 12:06 AM
BenVan_Kesteren1
Another user within my organisation was tasked to create a survey form which has been done. Report template has been created and can be manually exported no worries.
I am now wanting to create an Integromat workflow to generate a report and email it through, each time a survey form is completed. This is the first time I have had someone else create the survey, and then I am having to create the integromat workflow.
When I go into integromat and try to create a new webhook based on this form, I do not see the form I am looking for, in the drop down list (but I do see all survey forms created by me). I am wondering is this a limitation of the software? Or is there a workaround and a webhook can still be created and my integromat system be created?
has anyone else noticed this?
IsmaelChivite
Esri Notable Contributor
Hi. Sorry Ben, only the owner of the survey can attach a webhook to it.  Integromat and Flow connectors will only show the surveys you own.
IsmaelChivite
BenVan_Kesteren1
Hi Ismael, thanks for the reply.
Cheers
