Can I Auto-Populate Fields in Survey123 Using Arcade Queries?
371
11-25-2025 07:39 AM
Pili
Inside a Survey123 form, is it possible to auto-populate a field based on a query executed using Arcade?
For example: I pass a customer ID in the form, and then I want another dropdown (such as the businesses that customer owns) to be filled dynamically by running a query like “give me the locations associated with this customer,” pulling values from expressions or queries against a feature service.
Thank you 🙂
2 Solutions
Neal_t_k
Honored Contributor
Ed_
by MVP Regular Contributor
Arcade is supported in Survey123 similar to how it is possible in ArcGIS Field Maps. For your use case, you will have to Survey123 Connect.
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm
https://www.youtube.com/watch?v=DQFTvrTWov4
Question | Analyze | Visualize
Have you ever wanted your surveyors to easily see the last inspection for a lot in ArcGIS Survey123? Well, you're in luck as in today's GeoSnap I am going to show you how to pull the most recent record of a survey by using the pull data function in ArcGIS Survey123 Connect. Have a question about ...
Neal_t_k
Honored Contributor
Ed_
Pili
thanks @Ed_ edd y eddie and @Neal_t_k , have a great day 😄
