Can I access published Survey123 forms on non-Android/iOS devices?
3199
04-24-2016 08:25 AM
JeffPuuri
Can I access published Survey123 forms on non-Android/iOS devices?  Like a Surface Pro running Windows 8/10 would make a good field device, but I was wondering if there is a Survey123 'app' for the Windows OS?
DanPatterson_Retired
JeffPuuri
Thanks Dan!
I had previously installed and had been using Survey123 Connect for building and publishing my survey forms, and did not see that there is a separate installer for the Survey123 client app on several other platforms besides iOS/Android.  Thanks for pointing that out.
Survey123 Connect​ - publish forms (need to have an AGOL login)
Survey123 (client)​ - consume published forms (same link again as Dan had previously provided)
HannahFerrier
For completeness sake:
The Survey123 App is available for Windows, Mac OS, Linux, Android, iOS and Windows Phone. Use the app to download your surveys and collect data.
Survey123 Connect is available for Windows, Mac OS and Linux. Use Survey123 Connect to create and publish your surveys.
Hannah
