That is great to hear Imran, I'm glad my comment was able to assist, even if it was only a little bit ![]()
Although I am not positive, from the error it sounds like you have reserved words included with your attribute column names. Try renaming the attributes to include your initials or something like ..."_IKP" at the end of the attribute name you currently have in the table.
Mr. Matthew Duffy, Thank you very much for the immediate response. Although your suggestion hasn't solved the problem; i came to know about reserved words because of your reply and i have used some of them in the name field. Now, i replaced those reserved words. Once again thank you very much for your suggestions.
I think those columns are columns that Survey123 adds a survey feature service by default - if you go to the item details of this feature service > Settings > is 'Keep track of who created and last updated features.' enabled?
Mr. Carmel Connolly, You have no idea how desperately i needed a solution for this problem. I am doing a survey as a part of my project related to health and i got stuck with this error. Now, i can go ahead with my work. Once again thank you very much for your valuable suggestion.
@Carmel Connolly, Thank you very much for your suggestion in solving the problem. Now i'm able to send the survey form to AGOL without any error. What i have done is disabling 'Keep track of who created and last updated features.'
I'm sharing the screenshot of the same.
