Calculations based on yes_no response
1098
02-01-2019 07:50 AM
JimmyErnst1
#yes-no
I need to make some calculations based on yes_no responses.  The questions are inside a set of repeats where the user gathers plant data from multiple plants along multiple transects.  At the end, for all plants selected 'yes', I need the total number of plants recorded and the total number of "bites" on those plants.  The following statement generates an error stating 'if' requires 3 arguments and only 2 provided.
if(selected(${yes_no},'yes'),sum(${countbites}))
Once I get this figured out, I will do the same with the number of plants recorded 'yes' and divide the numbers.  I'm sure there is a long calculation that can do this all at once, but for now, this will do.
Tags (1)
JohnMarra
You need 3 arguments in an if statement. ie. If I goto the store, I will have milk, if not, I will not have milk. With the three bolded things being the three arguments.
if(selected(${yes_no},'yes'),sum(${countbites}),[enter what will happen if no is selected])
if you don't want anything to happen, then it would look like this...
if(selected(${yes_no},'yes'),sum(${countbites}),"")
JimmyErnst1
That syntax still gives me the total # of bites, including 'no' responses.  Do I need another statement at the end where you have ""?    I need to do this for both yes and no answers but I need to do it separately.
JimmyErnst1
After entering some data, I notice the total bites only appears when I choose a species and then select yes.  If I select no, nothing is displayed.
Ex.  Species 1 - 'no' - 3 bites =  nothing displayed
Species 2 - 'yes' - 0 bites = 3 displayed
Species 3 - 'yes' - 4 bites = 7 displayed
Species 4 - 'no' = 5 bites = nothing displayed
Trying to learn this on my own with nothing more than GeoNet and the website.
JamesTedrick
Esri Esteemed Contributor
Hi Jimmy,
This is best done by having the calculation in the repeat section and then summing at the end.   I've attached a sample that does something similar - count the number fo children in the repeat section.  You do the number calculation in the repeat section based on yes/no, and then sum at the end.
