Calculation works in Connect and the Survey123 App but not in the Web Broswer version
1443
11-01-2021 06:33 PM
ZeroWu
I am trying to code into a Survey123 form 10 work day but I am having issues with the display of the web browser version.  It work perfect on the app but the browser remain blank.
DougBrowning
MVP Esteemed Contributor
Only thing I noticed quick was the field day.  day is a reserved word.
Is there a reason the types and settings sheets are not in here?  They would catch the errors like this.  It seems like you started from a blank excel and not a 123 template.  Going to be way harder that way.
In Connect make sure to start with a blank advanced template.  You could then copy paste values (very important) from this sheet into the template.
Hope that helps.
ZeroWu
I replace all "day" with another name such as "dayw" or "dayu" and replace pulldata field name from 'day' to 'dayw' in the media csv file. The web version still won't do the calculation.
Thank for the helps.
