I have a survey with numerous string fields (select one and select multiple questions) and want to create an integer field that provides a score based on what was entered into those string fields. In Survey123 Connect, I successfully set up conditional statements to assign these scores and the calculations appear to work correctly in the form preview. The calculations don't show up on my mobile device when I'm filling out the form, which is a little disappointing but from what I understand is just a limitation of using calculations in Survey123, but the REAL problem is that these calculations don't even show up in my ArcGIS Online feature layer after I've submitted (all other fields do). I have attached my XLS form and can share my hosted feature layer if that helps with problem-solving. Thanks! James Tedrick
