Building a Report from Survey123 Data
2304
12-06-2016 09:10 AM
JoeFlannery
Honored Contributor
Survey123 is a great way to capture information in the field from an easy to create form.  However, the job is not complete until one can take the gathered field data and publish a report.
Let’s assume that you’re Survey123 data are not being committed to an on-prem enterprise geodatabase, but instead are located in ArcGIS Online.  Your data and related tables plus attachments can be download from ArcGIS Online to you desktop, but now what will you do?
Having a file geodatabase with related tables and perhaps photo attachments, how will you create canned reports?  Will you use the Report Wizard in ArcMap to create a report?  Will you use Microsoft Access to create your report?  How often do you need to download your Survey123 field data from ArcGIS Online?  What is your workflow?
I am interested in hearing from anyone who can share experiences of using Survey123 from field to final report.
BrandonArmstrong
Hi Joe,
A little late, but wanted to provide an update for anyone that does come across this post.
Survey123 DOES provide the ability to generate reports!  Please refer to the linked documentation and Blog below for more info.
If you are not already leveraging this capability, please try it out and let us know what you think!
Print survey results—Survey123 for ArcGIS | ArcGIS
https://community.esri.com/groups/survey123/blog/2017/07/26/introducing-custom-form-report-templates...
Best Regards,
Brandon
BrandonArmstrong
Hi Joe,
Best Regards,
Brandon
JoeFlannery
Honored Contributor
Brandon:
Thank you for the reply.  Yes, I have worked with the new report template capabilities in S123.  Well done.  Thank you for your time and additional information.
