Begin repeat
1196
06-11-2019 03:19 PM
StephaneMoisy
Hi all,
I want to integrate a "begin repeat" function in my form according to a constraint. This means that the user can only add after having previously filled in certain fields. I've done some tests, but it doesn't work.
Thank you for your help.
#survey132
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Stephane,
The easiest way to implement this would be to have the repeat not be relevant until the required fields have been filled in.  Constraints don't work with groups/repeats, only questions.
StephaneMoisy
Hi James,
Exactly what I did and it works fine.
Thank you very much.
