Begin repeat in survey123 not allowing multiple values in select one question
5578
14
05-05-2017 12:29 PM
IngridMans2
I have a survey for bird sampling surveys with a few header questions about location conditions, and then a repeat group of questions about different kind of bird species observed.  The species type question is a select one type referencing a list of choices with over 200 species codes.  Any time you add another entry in the repeat group, the value in the species entry defaults to the previous value.  If you change it, it also changes the PREVIOUS entry.  We need to address this ASAP.
Tags (1)
Hernán_P_Martínez_M_
Dear, ¿What is the solution?
JamesTedrick
Esri Esteemed Contributor
Please download the latest version of Survey123 (2.1.6) and verify that the issue has been addressed.
youngpark
Hi, James
I have a very similar issue although I am using the latest version.
JamesTedrick
Hi Young,
I'm not seeing the issue described above, autocomplete values being overridden in a repeat, in 2.2.  Can you share the form that has this issue?
youngpark
thanks for the reply, James.
opps.  i was using 2.0.35 version.  I will test the new version tomorrow.
thanks,
