Batch upload records in Survey123
755
06-21-2023 09:18 AM
mcbouchard
Hello everyone,
Is it possible to batch upload records into Survey123 (the survey feeds a dashboard)? Instead of entering records one by one using the survey form, I would like to upload everything all at once. Can it be done? Does Survey123 have a question that will upload the file and update the dashboard (create points with related attributes)? This is something that we will do every time we come back from the field with new records.
Thanks for your help!
ZacharySutherby
Hello @mcbouchard
Are you using the Survey123 Field App or the Survey123 Web App? If you are using the Field App you can save surveys to the Outbox and batch upload them when they are ready to be submitted. Please see this documentation for more information.
Thank you,
Zach
mcbouchard
Hello @ZacharySutherby
We use the web app. We can’t use a field app yet, our organization has to implement/modify the solution to access the portal through vpn.
thanks for your help!
