Automatically advance to next field after radio selection
872
04-27-2022 04:32 PM
AKitch
Hi
Is there a way to script (or otherwise) the ability to automatically progress to the next or a desired field after the selection of a radio button option?
I'm using Survey123 Connect 3.14.262 for form editing and testing on an Android device.
Cheers
Adrian
by Anonymous User
Not applicable
Hi @AKitch,
Unfortunately this is not possible to customize or script. This is built in behavior of the field app and we do not currently support automatic tabbing/moving to next field from a select one. If you are using a text or input field, you can select enter or tab and it will move to next question, but this does not work for select one questions currently.
Regards,
Phil.
