autofill address in textbox when marker is selected in geopoint
1436
08-28-2018 09:22 AM
Pa_Lotus
when a marker is selected on some building, how to load address
in textbox
JohnathanHasthorpe
Hi Malla
- Can you confirm the version of the app you are using (and device)?
- Have you tested the Reverse Geocode sample available in Connect?
- Can you attach your survey to this post and I will see if I can repro.
General help can be found here: Geopoints—Survey123 for ArcGIS | ArcGIS
John
JohnathanHasthorpe
Hi Malla
John
