Auto-populate skipped questions with "Not applicable"
741
11-04-2017 11:41 PM
IzayPantanilla1
Hello,
We are creating a survey that has a lot of relevant questions. I'd like to know if it's possible to auto-populate skipped questions with the response "Not applicable."
In the example below, is it possible to automatically return the answer "Not applicable" for the toppings field if I answered "No" to the "Do you like pizza?" question. What formula/syntax should I use for this?
Thank you.
Izay
by Anonymous User
Not applicable
Hi Izay,
Yes, this is possible using the "null" esri fieldType on your select_multiple and then a hidden field with a calculation for the final answer. The "null" field type was introduced in 2.4 and is perfect for your use case. Using your example of pizza and toppings, this is how I would do it:
Note that only the like_pizza and toppings fields will get created in the schema.
Regards,
Phil.
