auto populate questions based on selected fields from a layer in survey123 web designer.
2938
06-24-2023 09:08 PM
AndrewCastilloTBSL
If I have a drop-down choice list of people's names that pulls those names from a layer, can I configure in survey123 web designer so as that if I select a name it auto-populates other questions based on the name's associated attributes like phone number and email address?
IsmaelChivite
Esri Notable Contributor
No need to use Survey123 Connect. @AndrewCastilloTBSL   You should be able to do this through a calculation in the web designer. See this video for details.
@ScottBrown1  Your answer is correct for Connect users, but I think @AndrewCastilloTBSL was looking for a solution in the web designer.
(view in My Videos)
ScottBrown1
This sounds like you’re looking to use a pulldata calculation. This can be done two way. First, much like your using the search calculation for the list: https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-pulldata-quot-laye...
Second, to add a csv with the names and related information to the media folder of your survey in Connect:
https://community.esri.com/t5/arcgis-survey123-blog/use-existing-data-in-your-survey-the-pulldata/ba...
AndrewCastilloTBSL
so it looks like I will have to use Survey123 Connect then. Ok thanks.
IsmaelChivite
(view in My Videos)
