Are calculations broken in browser? "Send Email Test Failed"
853
10-13-2022 06:01 AM
neomapper
I have a send email test attached that works great in Survey123 Connect but it doesn't seem to work in a browser environment when I publish the survey. Is there a reason calculations don't work in a browser environment?
Tags (3)
Richard_Purkis
Hi @neomapper
I believe there is an existing BUG for this: BUG-000152166: HTML updated via question piping fails to display correctly in web forms.
The workaround listed is to use concat() function and then reference the calculation result in the question label
Let me know if this helps
