Hi! I'm using an existing feature service on our ArcGIS Server pointing to data in Oracle - one spatial layer and two related tables for repeat questions. The number of repeat questions are set using the number entered from a previous question. I.e., a user answers there were 2 persons involved. Then the repeat question, using repeat_count, will open 2 repeats to fill in name and other details.
The repeat_count variable creates a calculated field in survey123 schema that was not present in our database. Image: Survey123_Schema_Repeat_Count_MixedCase.PNG.
So we created the field forcing it mixed case to match. Our published feature service shows the fields in mixed case. Image: Feature_Service_Repeat_Count_MixedCase.PNG
Trouble is, the survey web form is attempting to submit the record into a field in all caps. We can see this in the AGS server log. Image: ArcGIS_Server_Log_Repeat_Count_ALLCAPS.PNG.
How do I edit the xlsform's _count field so that it is all caps? Or is there a better way to utilize repeat_count in existing feature services to build surveys? Is the calculated field necessary and can I work around it?
