I'm new to using Survey123 Connect to build public-facing surveys. I'm looking to understand if there's functionality where I can add a question that asks the survey taker to "select a point" from a layer on a map and provide an answer that references that point. The map would have pre-existing point data from a hosted layer, survey takers would select one of those points, and provide information about the condition for example. Is this possible?
Thank you!
