Add layer to Survey123 Connect
1247
11-26-2024 11:52 AM
temprobertcottreau131313
I am attempting to add a layer containing polygons to a Survey123 Connect form so that field staff can enter notes about individual polygons into the form.
How can I add this layer and allow a column to be populated by field staff?
Thanks to all.
Robert..
Tags (3)
RickeyFight
MVP Alum
ZachBodenner
MVP Regular Contributor
Is this a completely new form? If your spatial question is of type Geoshape, you will be able to add polygons. I recommend reviewing Ismael Chivite's article on geoline and geoshape if you haven't come across it already.
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-lines-and-polygons...
Happy mapping,
- Zach
I'd like for field staff to be able to click on a polygon in the map and add information to a column
ZachBodenner
Ah, I understand. In that case what you would probably want to do is build a Survey off of your pre-existing feature service:
https://community.esri.com/t5/arcgis-survey123-blog/working-with-existing-feature-services-in-arcgis...
Then in the web map that contains the polygon layer, you can add a link in the popup to trigger the opening of the survey.
https://community.esri.com/t5/arcgis-survey123-questions/survey123-with-field-maps/td-p/1300986
I've done this quite a few times and can give you some specific examples of how to structure the link if you wind up going this route and would like me to!
Happy mapping,
- Zach
