Add a hint to an entire group or repeat
4363
09-18-2018 08:27 AM
DataOfficer
I've set up an environmental survey that captures information on the site surveyed (including exact location) and the person surveying in the 'parent' group and then has a 'repeat' section for each species observed at each location.
The link will be shared with a large number of volunteer citizen scientists who may not be overly familiar with completing online survey forms and I want to make sure the concept of 'repeats' is clear to them. Is it possible to display a 'hint' for an entire group or repeat as you would for individual questions?
To illustrate I've attached a screenshot of the relevant section on the web form. 'Records' is the label for my repeat and I've added a 'hint' that does not display here. I want to explain to our surveyors that they can now enter multiple records relating to the site / location specified above and that they will need to click the '+' button to do so each time. Is there a way of using the 'hint' function on repeats or groups, or is there an alternative way of leaving instructions?
MichaelKelly
Hi there,
I think notes are what you need - see the following blog for details: https://community.esri.com/groups/survey123/blog/2017/11/14/understanding-notes-in-survey123
Mikie
MichaelKelly
Hi there,
Mikie
TI
Notes do not work for a repeat that has no records in it.
EricaNova
You have to put the note above the repeat, I think.
