Accessing individual values for repeat records based on another field within the repeat (outside of the repeat)
854
08-10-2022 06:56 AM
bb_geo_fish
Greetings,
I am trying to autofill a question in a survey form following a repeat (as a display for the user) essentially accessing the decimal value of a field in the repeat (any of the green fields, if it meets the criteria of a "station_type" (red)  field within the repeat. There is only 1 record within the repeat that will meet the criteria of the of the "station_type" field. It sounds confusing, but I think it could be easily done with a javascript function. I'm having trouble working with the array from the repeat properly, and have zero experience with javascript.
If there is an easier way to do this without javascript please let me know (I have tried a lot of different things).
Thanks in advance!
Katie_Clark
MVP Regular Contributor
If I'm understanding correctly....is this something you can do with the "indexed-repeat" functionality?
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformrepeats.htm#:~:text=To%20repeat%20....
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
bb_geo_fish
Yes! I had just resorted to that function. Thank you!
